Het grote VCC serienummertopic (VR2020 t/m VR2999, afgeleide modellen)
Perepandel
22 sep 2017, 21:35
Here it goes! This is from a Radiola "branded" VR2840.
I find it interesting that the "VR" part is in the middle of the numeration in my case...
23 sep 2017, 14:56
yep thats the case with EVERY non-philips branded clone machine. Erres Aristona Pye Radiola Novak, you name it.
25 sep 2017, 20:02
Except sometimes SBR and Erres. The former have their own numbering system while the latter sometimes uses the same number as Philips but with letters RS instead of VR.
Pet topic (stokpaardje in Dutch): technically speaking, the machines aren't clones but parallel models (produced alongside the Philips models on a second production line in the same factory or relabled some place in the logistic operation - omkatten in Dutch).
The only manufacturer (that I know of) that ever made clones of Philips videorecorder models, was Avex and even then they were probably more like CKD's (locally assembled from kits that were prepared and shipped by Philips) instead of proper clones (copies, license production). On a side note: If anyone has some good information on Avex that cannot be found readily on the internet, I would be really interested.
Generally speaking, clones of consumer equipment do exist, though. Nowadays, mostly from China where different factories work from the same reference design - with some minor variations in design and cost cutting. Turkish TV manufacturers such as Beko and Vestel started out that way as well, as did the Romanian TV manufacturer [Electronica I think they were called] in the late 1980's to compete in a more open market.
@Perepandel: thanks!
P.S. After having entered this example, I found a possible explanation for the use of RS instead of ..VR in case of the VR2840. Your Radiola 28VR40/20 has the same execution number /20 as two examples of the RS2840/20 that are listed (Normally, Erres used a /04 execution number while Radiola used a few different ones depending on the destination market). A model number (as well as the underlying 12NC stock keeping number) should always be unique so that could present a problem in this particular case. By using different letters, at least that part of the problem was solved. The underlying 12NC is hard to find out, since it is only publicly mentioned on the label of the original box (which almost no-one ever retains).
03 okt 2017, 18:48
oude Erres video 2000
Serienummer op foto 3
http://link.marktplaats.nl/m1210388624
Philips VR 2324
http://link.marktplaats.nl/m1210366220
Perepandel
07 okt 2017, 13:18
Philips VR2120; I have yet to find the sticker for the VR2220 part.
Notice how some of the logos have been covered with pen ink.
07 okt 2017, 21:56
Thanks! Made in Krefeld, like all VR2120. An early one, 1982 week 49.
The sticker on the VR2220 may be on the bottom?
09 okt 2017, 07:40
Vintage Philips Video 2000 cassette recorder collectors item
Serienummer op foto 6.
http://link.marktplaats.nl/m1210666089
09 okt 2017, 16:07
haha vintage EN collectors item, ik zat al klaar voor een gigantische goudgraversprijs... 20 eu!! das dan een keer netjes ondanks dat altijd afgevallen timerklepje.
11 okt 2017, 07:38
Erres video2000
Typeplaatje op foto3
http://link.marktplaats.nl/m1212911101
11 okt 2017, 10:01
En doossticker op foto 2, zoek de verschillen. Men deed heel erg weinig moeite voor submerkuitvoeringen.
Bob
13 okt 2017, 13:19
Hoi mae,
Dit zijn de bakken die ik ben me heb staan:
Een
VR2330/00A
WD 14 416 18 1800139
ook een
VR2424/00
KR 02431 522029
en, nog in doos, een
VR2414/02
KR 01421 469743
13 okt 2017, 23:41
Bob schreef:en, nog in doos, een
VR2414/02
KR 01421 469743
Leuke collectie :) Dankjewel, leuke aanvulling ik begin langzamerhand richting het aantal nummers te gaan waarmee ik wat gaten kan invullen en het systeem beter ga begrijpen. Heb je van die recorder in de doos misschien een foto'tje van de doossticker of als dat lastig is, de 12NC (artikelnummer) die daarop staat, en staat er ook een nummer van drie+vier cijfers op toevallig? Die laatste werden gebruikt voor verkoop in Duitsland.
14 okt 2017, 00:01
TODO: B&O 4471/00 vergelijken met VR2330/00. Die production runs zaten onmiddelijk na elkaar op dezelfde productielijn en allebei revisie WD17. De VR2330/00A kwam direct daarna en met revisie WD14, mogelijk afgeleid van een ander basismodel.
Ik heb inmiddels een voorlopig overzichtje van productielijnen zoals ik in het VCR-topic al heb gepost, maar dat moet ik nog even overzichtelijk maken. Coming soon.
17 okt 2017, 19:00
Te koop videorecorder Philips VR2340/51
Typeplaatje op foto 2
http://link.marktplaats.nl/m1214807995
18 okt 2017, 17:24
dat zal dan wel een 2324 zijn geweest, ze zijn bijna identiek op de stereospullen na. Als je de manuals uitspit zie je minimale aanvullingen voor stereo. uitwendig alleen dat schuifje voorop (stereo-bilingual). interne pluggen tbv koppen etc zijn al universeel. raar model eigenlijk, een kale instapper maar dan wel stereo geluid... zelden gezien.
