diferences between DSS - DSS940 fix
ducks007
07 feb 2019, 09:00
very nice ! 8)
Philips DSC950 DSS930 FT950 FT930 DCC900 DCC951 FV930 FC940 FC950 FA930 CD940 CD950 CDC925 CDC935 FW2017
Marantz DD82 / Hitachi HA 2500M / JVC A-L11
DCC130 / DCC175 / DCC170
ducks007
18 feb 2019, 15:24
Hello 8)
some news about my DSS940
the woofers are repair with new foams from the website link on previous post.
I've change the relays by new ones.
I've change the botom vinyl on the 2 cabinets (mat black textured close to original color, just little darker) and made some patches on the side with the original botom vinyl.
it's not perfect but they can not be one day on perfect state because the front have deep scratches (probably due to a fall down on concrete floor)
At this time, the result is not so bad and it sound good.
The next job was to repair the front grill because they are completley dead and on one all clips are broken (and I don't know how I can fix that)
glue
glue
glue
glue
woofers done
woofers done
Laatst gewijzigd door ducks007 op 18 feb 2019, 15:58, 2 keer totaal gewijzigd.
ducks007
18 feb 2019, 15:27
patch
patch
botom vinyl
botom vinyl
woofer in
woofer in
Laatst gewijzigd door ducks007 op 18 feb 2019, 15:41, 1 keer totaal gewijzigd.
ducks007
18 feb 2019, 15:29
woofer screw
woofer screw
front done
front done
little patch
little patch
Laatst gewijzigd door ducks007 op 18 feb 2019, 15:43, 2 keer totaal gewijzigd.
ducks007
18 feb 2019, 15:30
patch 2
patch 2
botom vinyl 2
botom vinyl 2
close front 2
close front 2
Laatst gewijzigd door ducks007 op 18 feb 2019, 15:44, 1 keer totaal gewijzigd.
ducks007
18 feb 2019, 15:34
twin front done
twin front done
electronics
electronics
original relay
original relay
Laatst gewijzigd door ducks007 op 18 feb 2019, 15:45, 2 keer totaal gewijzigd.
ducks007
18 feb 2019, 15:34
bridge for resistor
bridge for resistor
relay old and new
relay old and new
relay off
relay off
Laatst gewijzigd door ducks007 op 18 feb 2019, 15:48, 2 keer totaal gewijzigd.
ducks007
18 feb 2019, 15:35
new relay in place
new relay in place
ready to final assembly
first DSS before close
Laatst gewijzigd door ducks007 op 18 feb 2019, 15:50, 2 keer totaal gewijzigd.
ducks007
18 feb 2019, 15:36
first done rear
first done rear
first done front
first done front
2eme ready to close
2eme ready to close
Laatst gewijzigd door ducks007 op 18 feb 2019, 15:55, 2 keer totaal gewijzigd.
ducks007
18 feb 2019, 15:36
done rear
done rear
done front
done front
done
done
18 feb 2019, 17:00
Looks nice! :handgestures-thumbup:
Did you check the solder joints of the in/output, the 230V connectors and the voltage regulators on the board? Usually they are broken.
For repairing the front units, you might use these.
The 680 Ohm resistor works fine although nowadays I replace the 1k resistor (3334) with a 1k69/0,6W to get the same effect.
ducks007
18 feb 2019, 20:05
Thank you movieman ;)
of course, I've made a lot a solder joints on the board, just one broken on the 230v connector on the first DSS, but some dry soldering or suspicious so I've made a good preventive soldering everywhere I've see suspect solder :geek:
For the resistor i've ever this 680 Ohm because on my DSS 930 I've ever buy this one for the new relays and I've no 1k69 on my stock :D
Thank you for the link to repair the clips, have you ever done the job before with this parts?
18 feb 2019, 20:17
Nice job done, Benoit! :clap:
Erres SX5685 SX6393 SX6194 SR3390 - Aristona AR8530 SG1408 CD1202 - Philips GF403 AG2230 GA160 GA202 GA212 GL565 RH423 RH426 RH532MFB CD104 CD950 N2221 en heul veul Superscope. :D www.superscopeaudio.nl
18 feb 2019, 20:51
No I did not but they should work fine. Maybe you have to do some modifications... If the rubber inserts are still intact then you only have to use the nipples. Be aware that the screwholes of the speakers must be airtight!
Conrad has different items, these might also do the trick...
I would cut off the backpart of the nipples and then glue them onto the speakers' metal fronts...
ducks007
26 feb 2019, 11:03
Hello,
little busy this week, but just a little pict of DSS familly :)
DSS 930/940
DSS 930/940
