TWO ACTIVE SUBWOOFERS CONNECTION TO THE AMP
15 sep 2022, 22:57
Well of course I cannot tell you why seller says it is wrong.
You might consider not to do business with seller if he consists in not being helpfull. :think:
Erres SX6393 SX6194 SR3390 SX6290 - Aristona AR8530 SG1408 CD1202 - Philips AG2230 GA160 GA202 GA212 GF403 GL565 RH423 RH426 RH532MFB FA888 FB820 RH742 CD100 CD104 CD950 AH170 AH180 N2221 en heul veul Superscope. :D www.superscopeaudio.nl
Skagarack
15 sep 2022, 23:01
LOOK AT THE POST ABOVE!!!!!
I know , I´m worried about this seller.
But I can have two pieces for a good price.
15 sep 2022, 23:10
As I stated before, I don't think you want both subs not playing together so I don't think you should connect one sub to the left channel and the other to the right. I would connect both subs with each an own speakon cable. I would connect both yellow cables together to left +, both red cables to right + and both black cables to left -.
Skagarack
15 sep 2022, 23:15
Next problem:
https://rel.net/blog/2015-07-23/how-to/ ... ingle-amp/
They wrote:
If connecting 2 RELs, connect the black wire of each REL to a negative speaker terminal of the corresponding channel; twist together the red and yellow wires of each REL separately and connect each pair to the positive speaker terminal of the corresponding amplifier channel. In some instances, this will result in exceptionally high gain (output) from the RELs. If it seems simply too high in gain, please remove either the red or yellow wire from the twisted pair. This will reduce output by half and restore a natural dynamic.
If you are connecting to a Class D amplifier please consult the How to Connect to a Class D amp guide regarding the Black Wire grounding technique.
If you are connecting to a Class D amplifier please consult the How to Connect to a Balanced or Differential amp guide regarding the Black Wire grounding technique.
And I have got balanced and unbalanced connections in my amp.So is it problem? but I ve got A/B amp...
Laatst gewijzigd door Skagarack op 15 sep 2022, 23:17, 1 keer totaal gewijzigd.
Skagarack
15 sep 2022, 23:16
No, look at the Rel ´s page, everything is there :dance:
16 sep 2022, 10:06
Skagarack schreef: 15 sep 2022, 23:16 No, look at the Rel ´s page, everything is there :dance:
You should be alright then. Good luck. :D
Skagarack
16 sep 2022, 12:16
Thank you for helping me, Hoewie!
I will let you know later, how it is going.
I hope my amp will be ok :-)
Take care!
Jan
Skagarack
21 sep 2022, 22:33
Hi Hoewie,
I will get subs on Tue/Wed.
I will try them on a different amp, just in case .
If I connected them at B speakers terminals, I have to turn the switch to A+B speakers .
It should be ok.
Jan.
21 sep 2022, 23:23
:pray:
Skagarack
28 sep 2022, 13:55
So Hoewie, I tried it on my old amp Pioneer SX 450.
It´s got the switch for speakers+ turn it off together.
power OFF
Speakers A
OFF
Speakers B
Speakers A+B
So I had 3 wires going from speakon(connector for high level on the sub).
I soldered red + yellow wire together and connected it to R+ on the terminal for B speakers.
Black wire I connected to R- on the terminal for B speakers.
+exactly the same I did for the left channel.
OK.It started to play, but when I turned the switch to power OFF or OFF position, it started to hum.
OK I tried to remove yellow wire and connect only red and black.The signal was weaker , but hum was still there (on those two OFF positions).
OK, I said to myself when I was connecting my better amp.If it was connected with satellites to the same terminal A for speakers, hum problem will disappear.But I was thinking more...It wasn´t enough space to put tiny wires to the terminal with wires for satellites.
What´s the difference to put it straight to terminals on my satellite speakers?
So again:
I soldered red + yellow wire together and connected it to R+ on the terminal on the right speaker.
Black wire I connected to R-.
OK I did it.The sound is very nice, without hum.I turned AUTO ON on the sub, so without signal It is going off automatically.
So I have two subs for stereo listening and I´m happy. :whistle:
Jan
28 sep 2022, 22:51
Skagarack schreef: 28 sep 2022, 13:55So I have two subs for stereo listening and I´m happy. :whistle:
Hello Jan. Great to read that everything worked out fine. Are you going to investigate why the Pioneer SX450 is humming with the setup you made, because of course something can be wrong with the SX and the humming is not due to the connection of the subs.
Skagarack
28 sep 2022, 23:14
No, many people wrote about this problem.
I think if I connected it to another amp with OFF positions it would be the same.
SX 450 is 100% OK.
Active sub doesn´t like when nothing is comming from the amp.
If I connected these subs the same way as I did with another amp, it would be playing without problems .
29 sep 2022, 01:29
So if you would connect the subs and satellites on speakers A of the SX in the way you connected it to your better Amp, in would not hum?
Skagarack
29 sep 2022, 12:59
Hi Hoewie,
not at all. Be careful about the polarity.
J.
29 sep 2022, 13:11
Of course :)
So connecting the subs to Speakers B and the satelites to Speakers A is not recommended. Just connect it all to Speakers A and everything is fine. :D
