SX6541 ?
Psoas
Hello,
I have to box SX6541 Tropicalized version.
As I plug the main cord, the red power indicator does not work.
Do I have to unput a signal for it ?
thank you
Patrick
Yes its necessary to put a signal on it to switch it on.
If its stand stil for a long time maybe its take a while for the first time.
Psoas
Thank you for your answer. Unfortunately I only have the boxes and not the other parts. So I think i'm going to sell...
fastfolkert
Psoas schreef: 07 jan 2024, 13:32 Thank you for your answer. Unfortunately I only have the boxes and not the other parts. So I think i'm going to sell...
Why would you do that?
You can connect them to any amplifier, just make sure you set the input sensitivity correctly.
You can even hook them up to an iPhone, if you do ‘t mind making/buying a suitable cable. I personally like these small 541s….
Mancave op zolder met hifi uit de 70's-90's waaronder Quad, NAD, ARCAM, Meridian, Mission, Cyrus, B&W, DUAL en Philips natuurlijk!
