Advice - Philips 222, ga406 or ga418?
Armindo
Hi all. I now have 2 turntables, a 212 and a 877, I'm very pleased with both! Now it's time to buy one for the youngest Armindo in the house. These are the options: the 222, the ga406 and the the ga418. What do you think it's the best one, in terms of reliability and maintenance? Thank you very much, I I owe you many hours of auditory pleasure (and good advice on buying and using beautiful Philips devices). I ended up developing a passion for this brand.
Hopping to hear from you! Thank you in advance!
Best, José
22GA222, a perfect auto turntable.
Philips 22RH550+Teufel Ultima-20mk2, 22RH426, 22AH489. N4510, N4511, N4450, N2521, N2520, 22GA(1)408, 212, 312, 222 +GP401/412mk2 Shibata/MC-3 Turbo/AT-OC9XEN.CD204.NAD C352, C422, C521BEE+FB820. 22RH743+22RH544/79R.900:CDF200, FA911, FC931, FT930.LS3/5A.
fastfolkert
Fotohuis schreef: 29 mar 2024, 18:57 22GA222, a perfect auto turntable.
It is, but having 3 or 4 contacts/switches under the hood (required for automatic start-stop-return), it’s also quite prone to erroneous behavior.
FWIW: my 312’s and 212’s are more reliable than my 222, but not automatic…..
Mancave op zolder met hifi uit de 70's-90's waaronder Quad, NAD, ARCAM, Meridian, Mission, Cyrus, B&W, DUAL en Philips natuurlijk!
ALL those Philips players of 50 years old will need some maintenance. New LED's for the auto off, also in a 312, the same for a 222. Replacement of the power supply electrolytic capacitor due to the high ESR because the ripple on the main voltage will give problems for the FlipFlop circuit.
Cleaning and lubricate of the pitch control potentiometers and some other small things like the always broken main switch in the whole serie.
For the 222 Indeed the lamel switches, clean with IPA and lubricate with contact grease.
After this general maintenance these players are good for another 20 years when you have to replace again the rubber belt.
knarF
Philips 222 lamel switches.
There are two more, very good hide under.
And these two “hidden” ones are for muting the audio only. So no worries if they’ll falter.
Armindo
Thank you very much! I just I saw your answers. I ended up buying the cheapest one available, the GA418. The seller appears to be an honest one. I hope it arrives in good condition. Thank you very much to all, you are very kind, as always.
Armindo
Another subject, if possible. I have a Philips cd300/00 in maintenance. It reads CDs but doesn't show the track that is playing, sometimes the green lights disappear. Any suggestions? Will the elco kits available in the store solve the problem? Thank you very much!
Best, José
Jose, post this in section cd players / compact disc with title “ cd300 problem “ or so…
viewforum.php?f=7
Armindo
I did. Thank you! Best, José
Armindo
Good morning everyone. Now I have at home 3 Philips turntables, one for each of the Armindos, the old man, the middle one and the smallest - ga212, af887 e ga418. Can someone help me lubricate the machines? What products can be used, quantities and procedures?
Thank you all!
Best, José
