DIY Philips R 900 rack
ducks007
09 feb 2018, 14:31
Hello :wink:
I've find a R900 rack for the 900 serie but unfortunaly too far from my home.
So it give me an idee to make a "copy" of this rack and because I work on drawing office it will be nor very hard to do it.
I just should have your help (people who have the real R 900) to give me some dimensions :
for that, I've made a 3D drawing with letters for dimensions and if you can complete my list it will help me very much :pray: :clap:
let's go :dance:
Laatst gewijzigd door ducks007 op 09 feb 2018, 14:55, 3 keer totaal gewijzigd.
Philips DSC950 DSS930 FT950 FT930 DCC900 DCC951 FV930 FC940 FC950 FA930 CD940 CD950 CDC925 CDC935 FW2017
Marantz DD82 / Hitachi HA 2500M / JVC A-L11
DCC130 / DCC175 / DCC170
ducks007
09 feb 2018, 14:34
Laatst gewijzigd door ducks007 op 09 feb 2018, 14:59, 3 keer totaal gewijzigd.
ducks007
09 feb 2018, 14:35
Laatst gewijzigd door ducks007 op 09 feb 2018, 15:00, 3 keer totaal gewijzigd.
ducks007
09 feb 2018, 14:37
if the picts are too little, you can give me a mail to have the full size pictures :wink:
If you have picts of the real R900 it will help me too :wink:
10 feb 2018, 23:16
ducks007
12 feb 2018, 09:29
that's this one, thanks for this Philips publicity :clap:
12 feb 2018, 11:50
I have such a rack
will try to do some measurements later this week.
12 feb 2018, 23:51
Hi, I have most of the dimensions here. The rest I will try to add Tuesday or Wednesday.
Accuracy is +/- 1mm
Etageres (4x)
A: 450 mm
B: 540 mm
C: 426 mm
D: 565 mm
E: 7 mm
Plateau superieur
F: 490 mm
G: 655 mm
H: 466 mm
I: 680mm
J: 7 mm
Base
K: 20 mm
L: 465 mm
M: 465 mm
Sup
N: 240 mm (approximately, as it is mounted it is hard to measure)
O: 125 mm
P: 340 mm
Q: 485 mm
R: 125 mm
The sides O/P/R are 20 mm (identical to K), side Q is 5 mm thick
Montant droite + gauche
S: 125 mm
T: 1000 mm
For U/V/W/X I measured the distance from floor to glass plate etc.
Floor-bottom 1st glass plate: 363 mm
Top 1st glass plate: 370 mm
Floor-bottom 2nd glass plate: 512 mm
Top 2nd glass plate: 519 mm
Floor-bottom 3rd glass plate: 681 mm
Top 3rd glass plate 688 mm
Floor-bottom 4th glass plate: 870 mm
Top 4th glass plate 877 mm
The cut-outs for the glass plates are 72 mm horizontal (both sides) and 12 mm high. There are rubber inserts to place the glass plates on, thickness .... (I will measure)
Montant AR
Y: I didn't measure Y, but the cut-out lengte on the sides, which is 28 mm
Z: 40 mm
ZZ: not on your drawing, but the cable cut-outs (Y-Z) are each 20 mm above the cut-out for the glass plates.
AA: 125 mm
BB: 1.75mm
Laatst gewijzigd door Albert900 op 16 feb 2018, 19:10, 2 keer totaal gewijzigd.
ducks007
13 feb 2018, 09:20
Waouuu !
A BIG thank you ! :clap:
now I can adjust my 3d Drawing will all your informations :dance:
ducks007
13 feb 2018, 12:05
I've a little question about the right and left corner profile, what is the thickness of those profiles?
and you say O/P/R are 20mm and Q 5mm : is that a bend of 20mm and 5 mm of a plate with a different thickness or is this plate was 5mm thickness with 20mm bends hight ?
14 feb 2018, 00:34
I added N and BB to the table.
Thickness of the metal used, columns as well as base and sup, is 1.75 mm.
Plate sup is thus also made of 1.75 mm thick metal, with bends of 20 mm (same for base). Except for Q, here only bend down for 5 mm, so there is some more space for a 900-series unit. As you can see on my picture the DSC950 just fits underneath sup, if Q was also 20 mm it wouldn't.
To measure Y and Z I have to take equipment out, will try to do this later this week.
ducks007
14 feb 2018, 14:38
Many thanks Albert, with all your informations, i've rearanged my 3D model :clap:
work in progress :
16 feb 2018, 19:15
I added dimensions for the Y-Z cable cut-outs. These are not centered between the glass plates, but all are at 20 mm above the cut-out for the glass plates.
Which format is your 3D design in?
ducks007
17 feb 2018, 11:13
Many thanks Albert.
I work with Solidworks (that's the software I used at my job) 8)
19 feb 2018, 22:56
Sorry for the topic hijack, :idea:... I think I will change this in a FB820/FB830 rack. The height is adjustable. Measurements are easy to adjust... :idea: The shelfs can be made from either glass or composite. Black hard material for kitchen workblades. Very sturdy and strong.
