connecting philips speaker 22RH544 Electronics
Santaklass
Hi everyone, I want know if I can connect speakers philips 22RH544 Electronics to an amplifier Radiola 682 with connection cable 5P DIN to 2x please. I own the speakers and want buy the amplifier Radiola 682 this afternoon and want know if it's a good idea to purchase it please?
bonjour, j'aimerai savoir si il est possible de connecter des enceintes philips 22RH544 Electronics a un ampli Radiola 682, et surtout est ce que je peux utiliser des cables de connextion 5P DIN et 2x enceintes vendu sur ce site svp merci d'avance car j'ai les enceintes qui sont connecter sur une table de mixage et je dois acheter l'ampli Radiola 682 cet apres midi
Hello. If a Radiola 682 has the same connections as a Philips AH682, than the MFB output are cinch. But there are suitable cables for connecting MFB cinch output to RH544 speakers. No worries.
Philips AH682:
Santaklass schreef: 11 jan 2024, 12:24 Hi everyone, I want know if I can connect speakers philips 22RH544 Electronics to an amplifier Radiola 682 with connection cable 5P DIN to 2x please. I own the speakers and want buy the amplifier Radiola 682 this afternoon and want know if it's a good idea to purchase it please?
I assume it's this Philips AH682, but than labeled as Radiola.
AH682 has RCA (tulp) MFB connectors, MFB544 DIN female. There are 2 ways of connecting you may consider.
1. Cable direct
a. DIN 5p - DIN 5p for connecting both MFB's
b. DIN 5p - RCA cable for connecting 1 MFB to amplifier
2. Adapter cable
a. 1st DIN 5p - DIN 5p for connecting both MFB's
b. 2nd DIN 5p - DIN 5p for connecting MFB's to adapter cable
c. RCA male - DIN 5p female adapter cable to connect amplifier to previous mentioned cable (b)
Check suitable cables and adapters here : https://shop.mfbfreaks.com/product-cate ... diokabels/
Santaklass
Bonjour, oui mon ampli Radiola AH682 est exactement le meme que le philips en photo, donc si je comprend bien je peux connecter mes enceintes philips 544 sur la sortie MFB out en RCA j'ai le cable DIN 5 broches vers RCA, mon empli est partie en revision car quand je l'ai brancher hier il gresillé donc une petite revision ne lui fera que du bien, j'aimerai savoir si sur l' AUX tape B est une entree car ma tele est mes platine technics 1200 MK2 sont branche sur une table de mixage pioneer DJM400 2 pistes, je voudrais savoir si je peux me servir de l'AUX tape B pour avoir du son, je vous remercie de l'aide que vous pourrez m'apporter.
Hello. I translated your reaction with Google Translate because my French is bad.
Dutch translation wity Google Translate:
Hallo, ja mijn Radiola AH682 versterker is precies dezelfde als de Philips op de foto, dus als ik het goed begrijp kan ik mijn Philips 544 luidsprekers aansluiten op de MFB out RCA uitgang. Ik heb de 5 pins DIN naar RCA kabel, mijn vulling is onderdeel in revisie want toen ik hem gisteren inplugde kraakte hij dus een kleine revisie zal het alleen maar goed doen, ik zou graag willen weten of op de AUX stap B een ingang zit omdat mijn tv mijn technics 1200 MK2 draaitafel is aangesloten op een pionier DJM400 2-sporenmixer, ik zou graag willen weten of ik de AUX-kraan B kan gebruiken om geluid te krijgen, ik dank u voor de hulp die u mij kunt geven.
My answer in English:
1.
Yes you can connect your RH544 speakers to the MFB output of your Radiola. Like you say, you need a stereo RCA (2 x cinch) to 5 pin DIN to one 544 and a DIN to DIN from this 544 to the other. See webshop: https://shop.mfbfreaks.com/product/5p-d ... luitkabel/ and https://shop.mfbfreaks.com/product/phil ... abel-1-5m/
2.
If your Pioneer DJM400 has a PHONO pre-amplifier on which your Technics SL1200 is connected and if the Pioneer has a LINE output, then you can connect that to the AUX of your Radiola. If not, than you have to connect to PHONO-in of the Radiola.
EDIT: I Googled for that Pioneer DJM400. The picture shows it has a PHONO in (switchable) so I presume it has a PHONO pre-amp built in.
Pioneer DJM400 connections:
Good luck. :D
Santaklass
hi thank you for your help and sorry for the french language, your first message was traduct in french in my coputeur so i asked my question in french but english is good for me.
I send my Radiola 682 to be clean cause when I connected it I had a lot of noises and I guess it was stock in a garrage and it needed to be cleaned a little bit.
I will have it next week so I'm impatient to try it and connect everything,
After thinking I guess I didn't need the Radiola 682 cause my speaker 544 are connected to the master out of my mixer pioneer DJM 400 cause with out the mixer the speaker was realy loud on low and didn't really know how to have a good sound with them with my TV. With the mixer I can play with the hi and the mid and put less and the low, I have all the cable 5 pin Din to RCA and Din to Din between the speakers.
I also have 2 beowox S30 speakers with 2 pin Din cable to connect to the Radiola 682 I will try to connect all of them on B+MFB and see what i will get.
Sorry for my late answer I wasn't home for a few days,
All the best
Santaklass
Hi Guys,
I need help with a piece of my Philips 22AH682,
I couldn't take a better picture of it but i wrote on the pic what I could find on it R814 3w 270 omek micron 88,
I found a service manual of the philips 22AH863 and on this manual the R814 is writting 47 and on the another page i could find 47 ohms 1/2w and the series number is 4822 116 51103.
I don't have any idea which piece is, if still exist wher I can find it or with what i can't replace it ,
If someone have an idea about this piece and where I can find it ?
Thanks in advance with your help
It’s a 270 ohm 3 watt resistor and it is part of the power supply.
It should be 270 ohm so this one is ok. No need to replace it.
It is probably replaced before.
Santaklass
hi,
my biggest problem the sound with my 22AH682 is horrible when I use the volume botton up or down the sound cracks and it's the only piece we found with problem,
thanks for your answer
This resistor and the +5 (+13V) is of absolutely no influence to the audio (amp or preamp).
It powers part of the radio circuit
The servicemanual can be found here
